TwinTurbo.NET: Nissan 300ZX forum - These are all searchable.
Subject These are all searchable.
Posted by BobbyT on June 11, 2008 at 3:29 PM
  This message has been viewed 116 times.
In Reply To how do you know if a cylinder is firing? posted by Jaskozx on June 11, 2008 at 02:46 PM
Message If you pull a coil pack connector, the engine should drop revs and sound differently. If a cylinder doesn't respond, it wasn't firing.
You can pull your injector connectors (with the car off) and test the resistance of the terminals with a multimeter. 10-14 ohms is considered in spec. I'd do them all just to give you an overall picture.
Cleaning the injector & coil pack connectors with electrical cleaner and then coating them with dielectric grease is a good start before going on to other issues.
